-   -   Alternator wiring question (https://67-72chevytrucks.com/vboard/showthread.php?t=111634)
miket 07-14-2004 08:33 PM
Originally Posted by BobbyK
Mike I just read that link.I'm not aware of an internal resistor.
Soldering a resistor in the "L" line is easy and proven to work.
Yup me either---and I just rebuilt the one I am trying to install and I didn't see anything of the kind...
miket 07-14-2004 08:42 PM
Not to beat a dead horse here, but I looked at how my CS144 is wired in my 94 Caprice...it has a single 4 gauge running over to the battery and only two, maybe 18 gauge, wires coming out of the plug....now I know this car has a PCM but how does the alt sense the load and adjust accordingly? There are only two brown wires and one is for an light and the other is voltage sense. There isn't even a jumper from the charge termical over to the plug...wierd. This is roughly the same car my truck alt came out of.
BobbyK 07-15-2004 10:16 AM
Sorry Mike,I don't know how GM wired up the Caprice.
I'd need a schematic to figure it out.
Almost sounds like a one wire set-up,in the way the charge wire goes directly to the battery.
I can't see GM useing a 1 wire set-up though.
I'm sure there is a load signal getting to the ECM somehow.
miket 07-15-2004 10:57 AM
Yes I think so.....thanks.
miket 07-15-2004 05:03 PM
Finished
Well it's finished. Drove it a while ago...phase 1 is done...phase 2 will be the power wire upgrade and distribution block.
BobbyK 07-15-2004 07:16 PM
Glad it works.
Good job!
miket 07-15-2004 07:49 PM
Glad it works.
Good job!
Hey thanks for your help!!! :D
