Re: a/c help needed.
38*F wow, thats amazing! mine is still only at about 80*F , but i havent had much time to tinker with it yet. today is supposed to be another 100*F Texas heat wave so i'm not leaving the house unless absolutely necessary!:devil:
if you had that off then you know if the blender door control is ok?not broke like my #2 |
HTX86chevy: Keep in mind....this was last night when it was maybe 80°F outside. However, after taking it out today....it was ice cold when moving . Forgot the thermo so I don't know the exact temp, but it was nice and cold when moving. My problem now is I need to buy/make a cover for the top of my rad, and space the fan farther into the shroud so it works better at idle during the day when it's 100°+ out. Gotta get that air flow across the condenser, and having a 4 row rad doesn't help.
Motornut: My blend door's clip is broken too. But as of right now the local dealer is out(should have em on wednesday), and it only is sending a very small amount of air to the floor, and as a result keeps my feet cooler, so for now it's ok with me that it's broken. Also, dealer no longer stocks the seal I asked about, so I'm gonna have to figure out my own way of doing it. |
Camper shell tape - cut it to appropriate/desired width. Pipe insulation on a roll - often sticky on one side and metallic on the other side, foam style.
