-   -   ? (https://67-72chevytrucks.com/vboard/showthread.php?t=59062)
phantom dually 07-03-2003 09:02 PM
Why did you have to use a spacer at the rear?? Also are the tires and wheels turning without rubbing the fender well??
SCOTI 07-03-2003 10:01 PM
Why the spacers? Well . . ..... I'm a cheap f**ker. When I spend money, I want it to go a loooooooooooooong way. So, I bought the wheels in a car pattern w/the correct offsets for most GM's so if I get a chevelle, GTO, or camaro on down the line, they'll bolt right up or if I need to sell them I've got a lot more potential for buyers (plus they were originally for my 67 which has a car pattern).
Oh, just the rears use spacers. The front rotors are machined/re-drilled.
phantom dually 07-04-2003 11:38 AM
So the 5.25 backspacing is correct for the truck??
SCOTI 07-04-2003 12:08 PM
For the front, yes. That is the same 'front dish' that would be on a stock 7" corvettte ralley. The back spacing on a 7" ralley is 4.25 so I just had to add an inch to the inside measurements.
I've seen alot of people lately using longer upper arms (ex:Turners) to correct alignment/shim issues, but I try & keep the track width as close to stock (narrow as possible) because I hate it when the tires scrape the outer fender lips while turning. On my 67, the lower arms have the balljoint area sectioned & moved in about 3/4.
mike reeh 07-04-2003 04:58 PM
more like smart f***er than cheap f***er
nice truck
mike
SCOTI 07-05-2003 12:19 AM
Thanks Mike.
N2TRUX 07-05-2003 02:11 AM
Scoti,
I found a pic of your 74's older brother...
http://www.dropndrag.com/shows/shows...e/DSC05334.JPG
SCOTI 07-05-2003 01:41 PM
Hhmmmm . . .... that's cool. I could live w/both of them in my driveway. But . . ..... which one to drive?? It would be tough to decide every morning :D .
Bobs76 07-05-2003 06:41 PM
Bumper brackets
SCOTI I have some brackets if you want em. I have an extra set just sitting here. I am hauling the truck (or whats left of it) to Mississippi on the 18th. If you want the brackets you can pick them up or just pay for the shipping. :metal:
SCOTI 07-06-2003 11:10 AM
Thanks.
