Re: '69 GMC 305 V6 not running right
They do and are just as sensitive to point adjustment. Its the disign of the cam in the dist it has an aggressive slope causing the points to wear down quick. Also make sure the white cloth wire is still ok it is a restive wire for the coil. Make sure nothing else is running off of the wire also like a choke coil.
Well I ordered that distributor this afternoon and I got it in at 4 today. The only problem I see is that this distributor is the other type (the one with the v8 style mechanical advance) than the one on my brother's truck. Can I simply swap other the two distributors or are the cam gears different?
What do you mean? Is there only one vacuum connection? If so this is fine even better really just connect it to the port vacuum on the carb (no vacuum at idle but when throttle is opened there is vacuum). Mark the old dist and remove it make sure its on #1 cyl fire and check the gear should be the same. It will run better with this dist I would think.
