Re: Ripped the crossmember
any pictures of your front lower A ARMS???
No that I look at it they aren't 45*. Closer to 25*
Not much room for a watts. Ill have to move some stuff around back there.
There's plenty room, it would connect to the rear portion of your notch.
Yeah i could make it fit. I was talking about the center main pivot point of the watts. The universal weld on kits I've seen bridge over the differential cover. There is only a few inches between my cover and the cross member that that wire splitter is mounted to. Then my tanks are right behind that. I suppose I could get one of those that bolt up to the differential but I'd rather weld it to the axle. this is what im talking about
http://www.bcfab.com/Universal-Watts...it_p_1022.html http://www.alldayfab.com/Suspension-Components.html |
^^^ that thing is rad.
My buddy John is a fabricating wiz, he does some pretty trick stuff. Check him out on Instagram, might get a few ideas. Chassisfabjohn
