Re: Rear gear Ratio Opinions/Suggestions
2 Attachment(s)
As far as a sluggish 1st gear goes I have what I consider to be a rather healthy low end torque engine and I don't drag race the truck. This pickup has plenty of pick-up! :cool: God I'm witty. :) |
A few years later I swapped in a 300HP crate 350 to liven things up. The younger brother of an ex-girlfriend asked to borrow my truck for a high school day at the local drag strip. My truck did quite poorly that day, getting 17 second quarter mile. I ended up installing 3.73 gears after that, but once again it was miserable on the highway. |
custom10nut, if you share your tire diameter we can tell you exactly what your current rpm is at various speeds and what it would be with different trans and/or rear gearing at various speeds. Engine size and observed tach/mph readings aren't relevant.
I think they’re 29 or 30 inches tall :smoke: Is realist here. I never going to chase the dream of 18-20mpg (right now I get about 15 Hwy) My concern is the constant running at 32-3300 rpm at 70-75. Oh the truck will easily do it, but I don’t want to abuse the engine. |
the actual RPM your truck is experiencing in the upper left red box - along with various trans and gearing combos that have been mentioned in the thread. Obviously you won't want to do BOTH an O/D and 3.08 gearing - they're just listed for reference only. It shows why 3.73/700R4 is such a popular option (and why GM built zillions of modern 1/2 ton trucks this way) - it improves 1st gear acceleration and also reduces your cruising rpm more than a 3.08 does. But, several options can get you closer to what you're trying to achieve. Hope this helps!
Nice charts! Interesting to see the RPM increases from 55 to 65 and 65 to 75. More than I would have guessed off the top of my head.
Looks like the TH350 numbers assume no converter slip at all, which rarely happens even on a level highway. |
