-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   GA 72 big block truck parting out (https://67-72chevytrucks.com/vboard/showthread.php?t=819283)
heehawracing 03-09-2021 01:47 PM
Re: 72 big block truck parting out
Originally Posted by C101972 (Post 8891626)
Would you take $150 for the complete motor mounts? Thanks Chuck
i dont have the clam shells that bolt to the engine i have the parts that go on the frame is that what you are looking for
heehawracing 03-09-2021 01:49 PM
there in the 3rd picture i posted
71CHEVYSHORTBED402 03-09-2021 01:58 PM
Few things I may interested in, if available:
A. Fire arrester and hose
B. Engine bay wire clips, including those on the valve cover
C. A/C system clips.
D. S duct if nice.
E. Can be talked into a box of hardware.
C101972 03-09-2021 02:00 PM
I am interested in the plates that bolt to the frame and the mounts itself. Thanks Chuck
DeadheadNM 03-09-2021 02:04 PM
Originally Posted by heehawracing (Post 8891438)
Ok I’m see if there good tomorrow
Sounds good thanks. Basically after what all is needed to bolt a tank to the cab just like GM did.
heehawracing 03-09-2021 02:22 PM
ok what i have pictured in the 3rd picture ill do 150.00 shipped
Tmend 03-09-2021 02:24 PM
I’d be interested in both ac side vent assemblies sir if available and better photos. I have an ochre dash I want to add ac too. Thanks much
Attachment 2087820
heehawracing 03-09-2021 02:27 PM
Attachment 2087820
i only have one
Tmend 03-09-2021 03:13 PM
Originally Posted by heehawracing (Post 8891665)
i only have one
Is it crack free in good working order and what would you have for it shipped to 91304. Thanks much
FL71C10 03-09-2021 04:03 PM
Is that ashtray bolted in, or welded in? If it welded, I would be interested in the plastic glides on the dash mount for it.
C101972 03-09-2021 04:40 PM
I will take the motor mounts for $150, with the brackets that mount to frame and crossmember. Thanks Chuck
heehawracing 03-09-2021 04:46 PM
ok my paypal is heehawracing@bellsouth.net
thanks
C101972 03-09-2021 05:00 PM
thanks
Just sent you the payment. Thanks Chuck
heehawracing 03-09-2021 05:11 PM
got it thanks
un4gvn! 03-10-2021 12:25 PM
Any word on the defrost vents?
FL71C10 03-10-2021 12:57 PM
I texted you about the headlight buckets and retainer rings last night. Also wondering about the ashtray plastic slides.
heehawracing 03-10-2021 01:08 PM
defrost vents are black
heehawracing 03-10-2021 01:09 PM
text sent
heehawracing 03-10-2021 01:11 PM
Originally Posted by DeadheadNM (Post 8891399)
Just the rubber grommets for the lines, not the lines themselves. And the bolts etc that secure the gas tank in place inside the cab, and the pads the tank rests upon please.
most rubber parts are missing or broken i have a complete set of tank retainers and bolts 28.00 shipped
heehawracing 03-10-2021 01:14 PM
2 Attachment(s)
Originally Posted by 70STOVEBOLT (Post 8891349)
What kind of shape are 400 badges in?
pictures
C101972 03-10-2021 01:19 PM
Any idea on the door hinges, what kind of shape are they in? And if so how much for them? Thanks
heehawracing 03-10-2021 01:34 PM
there no good lots of hard miles on them
Tmend 03-10-2021 03:35 PM
Still interested in the one drivers vent assembly if not cracked
heehawracing 03-10-2021 03:36 PM
just got it out the tabs are broken
DeadheadNM 03-10-2021 03:51 PM
Thanks. Can you post a pic when possible?
70STOVEBOLT 03-10-2021 05:05 PM
Originally Posted by heehawracing (Post 8892047)
pictures
I will take them. PayPal sent.
Tmend 03-10-2021 05:05 PM
Can you sent me photos to 8184382271 may still be interested thanks much ,Thomas
Leroy-B1 03-10-2021 08:32 PM
Pics of the cab rust?
heehawracing 03-11-2021 11:57 AM
cab sold to leroy-b1
old51sedan 03-11-2021 12:02 PM
Sent you a PM yesterday in regards to the gas pedal, have you had a chance to read it?
heehawracing 03-11-2021 02:13 PM
gas pedal 100.00 shipped im not sure if it will work on your 292 search this board im sure someone will know
C101972 03-11-2021 11:30 PM
Are you selling the windshield and rear window stainless trim? Thanks Chuck
heehawracing 03-12-2021 08:19 AM
sold the cab with the glass in it
old51sedan 03-12-2021 09:34 AM
Thanks for the reply, I'll do a little research first.
Kustom64 03-12-2021 07:39 PM
Put me in line for the gas pedal assembly!
heehawracing 03-12-2021 08:11 PM
will do
