-   -   400 Id (https://67-72chevytrucks.com/vboard/showthread.php?t=106276)
bigblock73 05-30-2004 10:38 PM
400 Id
I know it has been discussed before, but how can you ID a 400 from the outside? Arent there external weights on the flexplate or balancer? Something about the number of freeze plugs?
Thanks.
1972C10 05-30-2004 11:06 PM
three freeze plugs instead of two . and a differnt balancer
82 Silverado 4X 05-31-2004 12:57 AM
I'll go along with the external balancing on the flex plate but, my 77 Blazer Chalet has the original 400 and has only two freeze plugs.
plumbcut 05-31-2004 01:37 AM
the freeze plug thing isnt 100% accurate all the time, but its been a while since I figured out the discrepency, so use caution...
but the balancer and flexplate are both weighted and are dead give away's... A chevy by the numbers sort of book (or a printout from mortec.com) would be an excellent identification tool also.
If the heads are off, look for the siamesed cylinders with the steam holes between bores..
pc
low 84 05-31-2004 03:22 AM
if its a small block with 3 freeze plugs each side of the block then it is definatly a 400. however, just because it only has 2 dosen't mean its not a 400, because there were some.
on the balancer, it is actualy a blancer, not a damper, so there is a section cut out of the outer diameter of the balancer to keep the assembly in balance. and there is a counter weight on the flexplate as well.
then there is always the casting numbers that you can look up
