-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   70chevy c20 (https://67-72chevytrucks.com/vboard/showthread.php?t=107021)
schu 06-06-2004 12:26 AM
70chevy c20
I'm looking to replace the drivetrain on my 3/4 ton 4x4 chevy. The 8 lug rear end burned up so I would like to replace with with higher gears.Also replace the front w/disc brakes 6 lug. Found a 72 K10 blazer parts truck with good drivetrain with 3:73 gearing,possi. Will this fit without changing or relocating the spring berches on the axle ? Would appreciate any information.
thanks, Charlie
Yukon Jack 06-06-2004 10:08 AM
Yes, spring perches will be in the correct location.
schu 06-09-2004 10:16 PM
70 c20 4x4
I read somewhere that there was some difference between c30 c20 and c10 4x4 spring perch width on model changes 67-70 to 71-72 ? Do you know of that difference.
I'm just looking for an easy swap and if the 72 K10 4x4 blazer drive line would replace my my c-20 4x4, I'm good to go. So you know for sure that the width is the same? Appreciate any help.
Thanks ,Charlie
toddol1971 06-10-2004 10:22 AM
some c20's had leaf springs while most had coil. If yours has coils then, the rear from the k5 bazer will need the pads & trailing arm mounts added.
72 CustomCamper 06-10-2004 01:44 PM
All the 4x4's are leaf springs...
Chuck
schu 06-10-2004 11:58 PM
I'm reffering to 4x4 drivetrains.
toddol1971 06-11-2004 11:26 AM
Thanks ,Charlie
Read above. c30 c20 & c10's are all 2wd. I guess you meant k30 k20 & k10. no biggie. I just thought you were going to salvage an axle off a 2wd to put on your 4x4. If that was the case then some 2wd's were leaf & some were coil. :burnout:
