Gas Tank Question
Would a 21 gallon Polyethylene Tank thats a direct replacement for a 67-72 burb fit under my 71 c10 without any problems ?
It will fit, but you must make a couple of alterations to your truck first.
1.) Remove 1" crossmember that the original spair tire sets up against. 2.) Notch 1 1/2" deep, the second from the rear bed bottom cross sill, so the tank flanges can rest against the bottom of the frame rails. 3.) Drill the frame for the J-bolts and strait bolts. 4.) Figure out some sort of gas filler for it. (A popular one is at this link: http://www.classicheartbeat.com/mark...t_gas_door.htm ) WES www.ClassicHeartbeat.com |
tank
i think you should check into this more before you buy one. price is about the same for both. i think the poly tank would fit ok if you can find a quality piece. good luck. |
