-   -   Engine repair in the truck. (https://67-72chevytrucks.com/vboard/showthread.php?t=110063)
WB72 06-30-2004 10:07 AM
I don't have access to an engine hoist, but want to replace the oip pan gasket and seals, can this be done in the truck?
What about replacing the cam, has anyone done this? does the grill have to be removed for this?
Fred T 06-30-2004 10:41 AM
The pan gasket can be replaced with the engine in the truck. Not sure on which engine you have, but in most cases you jack the front of the engine and disconnect the motor mounts. You might also have to pull the distributor to keep it from hitting the firewall. Instructions are in the factory service manual, available through many of the on-line vendors. Well worth the investment.
To r&r the cam, you need to remove the grill and the radiator. Again, instructions in the service manual.
buckola 06-30-2004 10:56 AM
You'll have to lift the engine about 3+ " and support it with 2x4"s or whatever to clear the flywheel. I removed my dizzy cap and had no problems with clearance. You also have to remove ( loosen)the fan shroud. Changing the seals? not sure of the difficulty but any "flat-back " work is a pain.
For the cam you have to remove the rad and of course all the other "in the way "paraphanelia. Theres enuff room for the swap at least in a GMC.
After just completing a cam, heads, manifold swap (still doing the headers) I would have to say... PULL THE ENGINE...it would be a helluva lot easier
70ChevyLongbed 06-30-2004 10:59 AM
I replaced the cam in mine without removing the grill... but I'll also vote for pulling the motor. That's what I'll do next time. :D
n737nc 06-30-2004 11:10 AM
I just finished a heads, cam, intake swap last weekend. If I did it again, I would pull the motor.
Nick
mrein3 06-30-2004 01:15 PM
I did a heads, cam, and put the old intake back on. I'd do that in the truck if that is all I had to do.
COBALT 06-30-2004 02:00 PM
I replaced my oil pan gasket a little over a year ago. I had to disconnect the motor mounts, loosen the transmission mount (and disconnect the linkage so it wouldn't get bent), loosened the exhaust brackets, took off the air cleaner and pulled the distributor, and then used a block to lift the motor by the balancer until I got enough clearance to get the pan around the counterweights on the crank.
Pain in the butt. Next time I'll pull the motor. Go rent an engine hoist.
LONGHAIR 06-30-2004 04:28 PM
The only time I ever did a cam in the vehicle was way back on my first car. The hot rodder in me was just beginning to grow. I can tell you that it can be done in a 69 Camaro w/o taking out the grille. I changed the cam, intake and had a valve job done too. I wouldn't go that route again........It is far easier to pull it out.
WB72 07-01-2004 11:08 AM
Sounds like I'll be pulling it. (the engine I mean)
Fred T 07-01-2004 11:16 AM
To each his own! http://www.fradsplace.com/icons/icon12.gif
What engine is in the truck?
WB72 07-01-2004 06:04 PM
It is a 350 with a TH350.
