-   The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=12)
-   -   No Power - Windows & Door Locks (https://67-72chevytrucks.com/vboard/showthread.php?t=112483)
nnbc 07-20-2004 09:35 AM
Power windows and door locks have power to them but the ground seems to have a problem. The power was checked going from the fuse both through the secondary both and it worked properly. The ground was checked that comes through the secondary box and it too was working properly.
The windows and door locks work intermentately when they do operate. When one does not opeperate the other also does not. Is there a common ground before the secondary box for these if so where should I look?
NNBC :confused:
99-2door 07-20-2004 06:46 PM
Sounds like the driver's switch is either coming unplugged or crapping out. Neither side will work without the driver's switch working properly. Can't get anymore specific than that without at least a year model.
nnbc 07-21-2004 09:19 AM
More info
The truck is a 1988, 1500, extended cab
