-   -   Are these necessary? (https://67-72chevytrucks.com/vboard/showthread.php?t=122141)
Smokin72on20s 10-04-2004 11:55 PM
stainless steel exhaust flex joints, if you have a high performance motor should you consider putting these on? are they worth getting?
Longhorn Man 10-05-2004 12:05 AM
If your exhaust is hung from the frame with rubber isolators, then these are not needed. They may help a little if your pipes are secured real tight, but they are a PITA when they rust out after 5years or so, even though the rest of the exhaust is fine.
1972C10 10-05-2004 12:19 AM
I just get my pipes welded straight to the headers and dont worry about it.
High performance motor has nothing to do with leaks its weak motor mounts. I run solids and dont have leaks Before i went to solid i would have to change gaskets every few months Now gaskets last untill i pull the headers.
68w/sbc406 10-05-2004 12:38 AM
i put one of those on my straight 6 cause i kept going thought exhaust doughnuts. it helped. but i dont have them on the V8 now.
