Taking off Harmonic balancer
It seems to be on there real good. I'm using a Harmonic balancer puller but it seems to not want to come off. I don't think I'm suppose to wack it with a hammer. Any suggestions?
Harmonic balancer
No It is not a good idea to whack it with a hammer.Did you take the bolt out of the center. When you put the harmonic balance puller tighten the bolts good then you need to turn the center of the puller and the balancer will start to come off very slowly. You do not want to grab the balancer by the outside to pull it off because there is a rubber ring in the center and you will just pull the outer ring off. If you have any questions let me know. Good luck.
Tom :bowtie: |
make sure the big washer is off too. I have had that problem a few times.
I had a cheap puller that the bolt was locking up on It was made of a soft metal. I went and rented one from A-Zone that was a gold color and it came right off.
