-   The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=38)
-   -   Ruff Idle (https://67-72chevytrucks.com/vboard/showthread.php?t=126565)
RANDY COX 11-06-2004 11:02 PM
Ruff Idle
well got my burb on the road but it's not running smoothly when idleing it will idle up and then down to almost die then pick back up,sounds as if it has a miss but has new plugs and good wires,and its wired right,wondering if it's in the points,they look new though,or maybe the timeing tried to adjust it but same results.the carb has been rebuilt could it just be it.any help would be appreciated Thamks Randy BTW it's a 250 six.
CG 11-07-2004 12:50 AM
im no expert on this but mine was idling funny like that and i found one of the rubber vacuum plugs on the carb was cracked. i put a new rubber plug over it and that took care of the problem...im not running a six but considering you just had your carb done at least its something to look for...good luck
tjhooker125 11-07-2004 04:04 AM
Definitely sounds like a vacuum problem, as in a vacuum leak.
RANDY COX 11-07-2004 07:17 PM
found the problem it was the carb after of course i redid the timeing re-checked plugs changed the wires and still same problem well it was the bottom gasket flipped around the wrong way I flipped it over and wala problem was gone went out for a test drive and did good so there's another 70 burb 4x4 on the road now so look out if you see me give me a holler.Thanks for yalls feedback,Thanks Randy
