WTB: Someones original factory Build Sheet
Would like to buy someone's *original* factory build sheet. The piece of paper commonly found in/behind the seat.
Thanks. |
I will look to see if I still have one from a 69 custom 10 that was built in Freemont, CA. It is the only one I have ever found while re-upholstering the original seat, and I have done a bunch. I will get back to you. Tim
I have one from a 72 Seierra Grande 2wd I parted out. Also have the wood grain glove box door with option sticker to go with it.
Dan72cst, sent PM.
Thanks Ozark Tim. I'ld be interested if you find anything. -Roger |
3 Attachment(s)
Here's my build sheet and glove box door. I want $50 for both.
so this is under the cover of the seat?
It usually faces the gas tank and it's between the springs of the seat and the cushion (on the backside of the seat back)
