Interesting turn-signal issue
Hey guys!
What would cause one signal light to work normally, 4 way flashers to work normally, but the other signal light to stay on steadily? This isn't on my truck, but I figured that they should be the same... |
If it stays on repeatedly when the lever is depressed, that would be a bad bulb or messed up wiring on that side.
Flashers have a "seperate" circuit in most vehicles so you can't really use them to test anything but theirself. |
I would have to say a bad bulb on the side that stays on.
yeah bulb, probably brake light or taillight of that side. i had the same problem back in june or july.
