-   -   starter (https://67-72chevytrucks.com/vboard/showthread.php?t=131530)
ronsk10 12-14-2004 05:41 AM
starter
do anyone have a picture of a staggered bolt starter and a straight starter so I can compare to what I have. Thanks
hotrodhomi 12-14-2004 10:42 AM
I don't, but if you can post a picture of what you have I could tell you what it is.
piecesparts 12-14-2004 10:09 PM
Do you have 153 tooth flywheel or flexplate or a 168 tooth plate. The staggered bolt pattern goes with the 168 toothed plate and the 153 toothed unit has the straight bolt pattern. Some after market starters have both pattern capabilities. Just to help.
ronsk10 12-15-2004 09:39 AM
thanks. I found out I have the staggered but I need the straight one
