Best bushings ?
I am in the process of planning a suspension rebuild. I will start with the DJM tubular upper & lower control arms which come with polyurathane bushings, bumpstops, and new ball joints. By adding new stock height coils I will have a 3" front drop. I will also be getting new rear 4" drop Westin Leaf Springs which come with polyurathane bushings. So, I don't need a big complete bushing kit to complete the job.
With all of the above I just need, I think, bushings for sway bar and end links. I am missing something obvious?, and which is the best choice manufacturer. I like the Energy Suspension new greasable sway bar bushings. By the way, I just changed my stock Tq. Converter with a Hughes 3000 Stall, it is as if I added a NOS shot, what a difference. Can't wait until spring to get back to the track now. :burnout: :gmc: Thanks. |
I like the idea of the greaseable bushings, but I have had my $3.99 a pair urethane bushings in my truck for about two years with no problems. For $8 you can replace all 4. Not too bad. :)
I was looking for rubber ones, so I went to all the local stores. I started with the place that sells Moog stuff, because that is my preference. They did not have rubber, and neither did anyone else. All of the urethane bushings appeared to be identical, so I went with the cheapest. Slonaker |
Did you replace your pitman arm when you rebuilt your front end Slonaker?
Slonaker |
Just wondering how you did it and kept it in alignment with that part itself. I know it needs aligned after the front parts are installed but I'm talking about just the pitman arm itself. Yes that is the one that connects to the steering box and center link. I have never installed any front suspension parts at all other than coil springs and shocks. I bought all the moog parts that were at the store. Moog, ACdelco, and some other one that I cant think of. I was told moogs plant burnt down or something like that and that acdelco and spicer have been used for moog now. Im not sure how true that is but I got all the best parts I could get.
If you are asking how to align the part with the steering box, it only fits one way. It is hard to tell with the nut still on, but the splines are shaped in a way that will prevent you from putting it on wrong.
BTW, buy, borrow, or rent a pitman arm puller. My auto parts store told me they did not have one to buy or borrow, and I broke several other types of pullers getting mine off. I went back to the auto parts store, and asked to look through their loaner tools. They did have a pitman arm puller. The guy didn't know what it was so, of course, he was sure they didn't have one. :rolleyes: With the right tool it comes off pretty easy. The nut is tightened to 150 or 175 ft lbs, or something like that, so an impact wrench might help a lot. BTW, I used swervin's article to do mine, and it was very helpful. http://www.73-87.com/7387garage/chas...n/frontend.htm PM me if you have any questions so that we don't derail this other guys thread any more than we have. :) Slonaker Slonaker |
