-   -   numbers off axle (https://67-72chevytrucks.com/vboard/showthread.php?t=14043)
Blue_71 05-29-2002 05:42 PM
numbers off axle
i looked everywhere where the cab is supposed ot be on this frame, and there is no numbers at all, either frame rail, top, side, bottem, nothing.... so does the numbers off the right side axle tube maybe tell me the year of the frame? i know its somewhere between 67-70, its 6 lug, and the right shape... the number is HA 07 11
Fast68Chevy 05-29-2002 05:59 PM
HA is 66-69 3.73, there are numbers stamped into the frame rails, in the earlier years they are in different places than in 71 72 sometimes.
good luck
Blue_71 05-29-2002 06:02 PM
so where would they be? the front of the frame has been cut off at the clutch bracket. its probably a 69, because the bed that was on it had 69 trim, but then again the cab had a 68 front clip
Fast68Chevy 05-29-2002 09:09 PM
good luck finding any numbers then, most all if not all of them in the first 4 years of this era are all on the front third of the chassis,.,.
theres a date casting code on the axle center section housing on lower backside webbing near where the axle tube slides into the cast iron housing, if you clean it off. will be either soemthing like K119 or B48, etc,
