67 Powerglide Colum Info and Parts
My 67 left the factory with a 6cyl and powerglide. A PO changed to a 307 with T350 but did not change the col.
Since I now have a tilt installed does anybody have info on the glide or need parts. I have several non-tilt cols but don't know which one is the PG - I am assuming the detent area is different but am not positive. I should also have a the PG neutral/safety and the PNDL indicator. Can someone help me ID these parts - number stamped on neutral/safety and pic of detent area? Does anybody need these parts? Thanks in advance - Bob |
67 Powerglide
Nobody left runnig a Powerglide?
Do you have a good pointer that isn't cracked with the fiber optic wire. I need the pointer for the 67-70 style column that goes behind the chrome top indicator.
Mark |
