-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   4x fng, so how do I tell? (https://67-72chevytrucks.com/vboard/showthread.php?t=142884)
krue 02-26-2005 12:05 AM
I just drug a 72 blazer home and was wondering how to tell what transfer case and front end it's got under it. It's a 6cyl with what I think is a 3 speed tranny.
How hard will it be to put a 4 speed in this thing and which would be the best and/or easiest to swap in. No major mudding and their ain't no rocks in South Mississippi!
Prerunner1982 02-26-2005 12:19 AM
probably has a dana 44 under the front, as far as t case.. is it divorced or attached to the trans? if its divorced it is probably a rockwell 221, but i dont know when they stopped doing that.. sorry not much help, sure the experts will come along and proved me wrong..
1FaastC10 02-26-2005 12:35 AM
definitely a D44/12 bolt. should be a closed knuckle D44, which IIRC is a little weaker than an open knuckle 44 or 10 bolt
72 CustomCamper 02-26-2005 01:02 AM
With a 3 spd it's more than likely a Dana 20 Tcase...
Chuck
Rod 02-26-2005 01:30 AM
If its a 72 will be an open knuckle 44 disc brake front and a dana 20 transfer case most likely...if no shift pattern on the knob and a shift pattern on the floor shifter boot retaining ring...and the shifter for transfer case moves to the left also to engage an axle..its a dana 20.
Could have a NP 205..but rarer with a 3 spd.
If it has the np 205..that easier to find the parts for to make it a 4spd. You'd need tranfer case adapter and a tranny to start.
1969 GMC 02-26-2005 03:37 AM
T221 was never offered in K5's and '69 was the only year they had closed knuckles. I bet its the 3 spd/Dana 20.
Yukon Jack 02-26-2005 10:18 AM
It won't be difficult to put a 4 speed in your truck but if you have a Dana 20 I would look for a 4 speed/NP205 combo to replace it with. Much easier to find that combo than an adapter to mate the 4 speed to a Dana 20.
You will need either a NP205 crossmember or drop the Dana 20 crossmember about 3/4" to 1". I beleive your driveshaft lengths will not need to modified.
Pretty straight forward swap.
