-   -   Proper horn button installation?? (https://67-72chevytrucks.com/vboard/showthread.php?t=146996)
whitesswj 03-22-2005 12:23 AM
I've never had a horn button in my 68 beofre. either i just ran a hot wire from a hot post to a button on the dash and then to the horn and HONK there you go or on the new 68 just use a scredriver and cross that little springy thing to the center and HONK.
I break down and buy a horn button from the jnk yard. 5.00 and all the stuff under the button
I got the button, little bowl looking thingy, the plastic ring, the 3 screws that hold that down and that little fierce looking disc that goes below that.
I put them in that order and a short keeps happening from the bowl to the nut that holds the wheel down. what's the missing factor here??
thanks sswj
whitesswj 03-22-2005 08:09 PM
ttt
Striker169 03-22-2005 10:17 PM
I would also like to know
whitesswj 03-23-2005 09:42 PM
once again. anyone with an answer??
sswj
whitesswj 03-27-2005 06:40 PM
ttt
Striker169 03-27-2005 09:39 PM
comon people someon is bound to know
whitesswj 03-27-2005 10:04 PM
:agree:
LUV2XCLR8 03-27-2005 10:17 PM
MINE'S NOT WORKING EITHER, SORRY, NO HELP HERE :lol:
whitesswj 03-27-2005 10:35 PM
luv why is it that you know just what to say when all seems hopeless???
btw where is everyone. normally i can get an answer within minitutes to any question or other post for that matter. what's goin on??
HOW DO I MAKE THE HORN BUTTON WORK??
LUV2XCLR8 03-27-2005 10:37 PM
IT'S A GIFT / CURSE :lol:
Robert1970C20rstbukt 03-28-2005 01:47 AM
Damn mine doesn't work either!!!!! :lol: 'Course mine's the '70 style wheel with the plastic cap. When I push the button it pops back like it should but there's something not making contact inside. I DO know that if you tighten the three screws on that plastic thing down too tight it won't release and it will stay shorted.
whitesswj 03-29-2005 08:47 AM
ttt
68w/sbc406 03-29-2005 10:10 AM
do you have power there? that is the first question.
68w/sbc406 03-29-2005 10:14 AM
what style wheel is it? i have all the horn workings to the 3 spoke style
jhow66 03-29-2005 11:33 AM
Just put the horn togather on my son,s Blazer. Here's how it goes:
1--wafer spring in 1st-cup side UP (outside edge rides on plastic part of wheel-hence no ground)-3 holes lined up with 3 screw holes.
2--metal cup with plastic insulator inside.
3--put metal cup with plastic insulator legs thru holes in wafer spring.
4--install 3 screws and tighten.
5--touch battery cable back to battery post (you did remove it before you started didn't you?). If horn blows lossen screws a little and center the wafer spring where it goes around the steering shaft nut.
6--If this does not work don't blame me, blame MURPHY
