What I got done yesterday. Blazer doors for Sale
2 Attachment(s)
Smoothed the heater box hole in the firewall. Still have to do the hole for the blower motor. I am going to run a HD Auxillary heater from Summit that puts out 28,000 BTU's and is super compact freeing up tons of under dash leg room. It is only 6.4"H x 9.4" W x 8.66"D and I am thinking running lines back under the rear seat and installing one back there also for the kids. Summit part no. SUM-991102 $159.95 and there is also a ducting kit that is available to for the defrost function for an additional $29.95
Good job.:D
Heater???
Does it run off the engine coolant or is it electric?
That's alot of heat. :cool: |
It runs off of the coolant. The only reason I wanted one with that many BTU's is I am not going to run the doors, and its going to loose alot of heat so I figured that a little more BTU's would help out. I found a super clean 70 Suburban for sale that I am going to pick up from the guy next weekend so the whole scope of the Blazer project has changed. Doors and Double wall top are now for sale as well. Thanks Jeremy
What shape are the doors in? Can you post pics of them, inside and outside and underneath? Thanks
:c2:
Keep us posted on the install progress I have a rear heater outta a suburban that I was planning on installing in my blazer just one of the many things I have not yet gotten to..
Here are the door pics. All of the angles that you could possibly want. The drivers door is very solid and has no rot on the bottom side of the door only minor surface rust. Tha passenger door has a small amount of rot on the front inside radius on the bottom part of the door (deffinatley repairable). As far as price I honestly don't know, make a reasonable offer. Both doors are complete and will come with everything as seen in the pictures. Thanks Jeremy
I didnt see any pics
Pics didnt show . If you got a good rear hatch you wish to sell put me up for it i need one . I only get a month or two of good summer so im not going to eliminate the top :hm:
5 Attachment(s)
Ooops forgot the pics. Here they come.
5 Attachment(s)
More
5 Attachment(s)
Still More
3 Attachment(s)
Last Ones
Sorry rear hatch is trashed as are most of them. The top is in great condition though.
LOOK PRETTY DECENT TO ME, I'VE PERSONALLY SEEN ALOT WORSE :lol:
Yah there not bad at all. If I had the room to keep them I would. Just the direction I am going to go with the Blazer now I am not going to use the doors. Thanks
you didn't post a price....
or at leat I didn't see one |
You did'nt see one because I did not post one. I don't know what they are worth. Make a reasonable offer is what I put in one of the other posts. I would think that $200 for the pair would not be to far out of line.
TTT for Ring Master
Wish You Were Closer, I'm Looking For A White Hardtop :(
I wish you were closer too because I have one for sale
Just for future reference all parts you list to sell on here need to be priced. |
