-   -   gas tank sending units (https://67-72chevytrucks.com/vboard/showthread.php?t=166419)
hobbz 07-31-2005 08:22 AM
i am going to need a new sending unit to get my drivers side tank working. my question is can i use a sending unit from a munaul tranny for my auto. ti diff is that the auto has 3 hoses and the manual has 2 hoses. where does the 3rd gas hose go to?
thanks
plumbcut 07-31-2005 10:50 AM
it was a return line used on some trucks... if you capped it off you should be o.k.
pc
hobbz 08-01-2005 08:21 AM
thanks, cause only 2 of them were hooked up anyways
Turbo85GMC 08-01-2005 09:25 AM
FWIW, I just took out my leaking gas tank this weekend. It's a manual shift, but the sending unit has 3 outlets. The sender in the replacement tank I got also has 3 outlets. They are feed line, return line, and vent. If your truck doesn't have a return line, you can just cap off that line on the sender.
(P.S. if you're looking for a 3 outlet sending unit, PM me. I'll be selling my extra one.)
