-   -   Front shock with drop? (https://67-72chevytrucks.com/vboard/showthread.php?t=168022)
Kopper 08-10-2005 09:30 PM
I have 2.5" Western Spindles for the front of my 81 and I'm in the process of putting it back together. I'm considering installing a set of 2" drop coils also. If I install the drop springs can I still use stock shocks or will I need drop shocks?
C&C Chevy 08-10-2005 09:46 PM
You can still use a stock shock but it's recommended to get a lowered shock anyway.
If you get the drop coils, you will have to get drop shocks.
jermasaurus 08-10-2005 09:56 PM
I nonticed that the KYB monomaxes say they can be used for up to 2" of drop.
-Jeremy
bigarmzz 08-10-2005 10:10 PM
in my opinion, and from what others have said.....i think the lowering shocks make for alittle bit of a rougher ride....
i spent the big $$$ and got deucshtec's (sp?)....there not that bad though
piecesparts 08-10-2005 11:35 PM
I lowered my truck with Bell Tech 3" spindles, along with 1" drop springs. To keep the front riding reasonable I use a stock length Rancho 9000 shock that has adjustable dampening on the shock stroke. It has worked fine for years and I can keep the front under control at high speeds. The shocks that are sold as drop shocks seem to stroke a little fast for my taste and the front rode springy. I dropped my truck in 1995 and it is still runnig strong. The highways in Arkansas on the one of the Hot Rod Power Tours was the worst thing I had to deal with, I-40 really is the pits, but I can run with the best of them.
bodydropped 08-11-2005 12:54 PM
im runnin stockers with drop shocks and it rides better than any drop shocks that ive ever owned
