-   -   Were to get B.B. mounts quick, I knew the 6 was gonna go but now? (https://67-72chevytrucks.com/vboard/showthread.php?t=17066)
ibjoker69 06-30-2002 01:18 PM
My life is life is like this, I always need something at the worst time. I was getting parts together to put the 454 in but wanted to do it in aug. but now have a bad rod knocking on heavens door. My model A is getting fixed from being rear ended from the last time the truck was down and I was using it as a parts runner. So I need something to drive in a hurry, and I have the block ready this seems to be the best way out. I know this has been answered before but I forgot the answer. I need motor bracket, mount, and frame towers any thing else?? And where can I get them fast, they need not be the best deal as I need them now. Thanks, in advance for your help, Joker69
Bill72BB 06-30-2002 05:37 PM
Thy Desert Rat he probably has some..
Bill:flag:
Super Chevy 06-30-2002 07:08 PM
Micah (sp?) is the guy to talk to about those,TTT so you can get these quick
t korinek 06-30-2002 07:27 PM
I've got a set out of a 70 that had a 402, I also have a set of B.B. exhaust manifolds, they could be shipped on tues. 100$ for the mount's & towers. Thanks Tom
ibjoker69 07-01-2002 11:16 AM
Tom, Is this all I need in the way of mounts? I wan't to get it all the way in at the same time. :confused: will there be more to buy? My Email is ibcoachhill@yahoo.com so you can contact me directly about shipping ect. Thanks, Joker69
Desert Rat 07-01-2002 12:23 PM
If he cant help you out i have everything to convert truck to a big block.Can go either way Long or Short Pump,Long Pump is way cheaper,i have both styles and plenty of it,and the 67-71 towers,and a set of 72 towers. gmcrat427@yahoo.com my name is Micah
Desert Rat 07-01-2002 12:28 PM
http://groups.msn.com/_Secure/0MwAAA...Q/Jan03_02.jpg
This is the correct parts for 69-71 only difference in 68 is upper alt bracket,and in 72 it changed also.i have all available.but ill have to check on shrowds my dad needs one,so i might only have a few left.
ibjoker69 07-03-2002 10:43 AM
Desert Rat, Thanks for the post. I don't need all the brackets for the motor itself, but I do need the mounts that attatch to the block. I don't see these in the photo, do you have them? Also I have read somewhere on here that there is a break in the years and the rubber mounts for one are cheaper than the other years, but that they will both work well. Any differences or ideas about this? Thanks, Joker69
Classic Heartbeat 07-03-2002 11:36 AM
What transmission are you going to use? If you are going to use a standard you will need the crossmember that goes under the bell housing. The BB crossmember is located in a different possition so it is shaped different. I don't have one, but I have had in the past. If you are installing an automatic you will be allright as far as the transmission goes, but you will need the frame bracket for the auto transmission (as they are different) and I may have one of those. WES www.ClassicHeartbeat.com
Desert Rat 07-03-2002 01:27 PM
i have used rubber mounts but id recommend new ones they are quite expensive they were well over $100,if on budget use truck sb motor rubber pads,and a big basher under mount.or goto 72 style.i have those. someone on here wanted said they were sending$$$ but its been a while.the tranny linkage frame bracket is different but you can certainly use sb one.if Wes dont have any,i have quite a few.
ibjoker69 07-03-2002 06:01 PM
Desert Rat, The question is more about the "clamshell" that bolts to the block. I don't see these in the photo. The second part was about the cost of the rubber mounts. Thanks for the further info, Joker69.
Desert Rat 07-03-2002 09:02 PM
rubber mounts go with this style in pic,clamshells are for 72 different tower all together.
