-   Engine & Drivetrain (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=24)
-   -   Trans (https://67-72chevytrucks.com/vboard/showthread.php?t=179634)
71 gmc sled 11-10-2005 02:30 PM
Trans
I have a 71 gmc long bed n i just got a turbo 350 trans w/ **** kit ect. My truck came w/ a 3 speed on the tree do i have to change the crossmember to an auto one or can keep this one im puting in a 350 . If anyone could tell me any probs im going to run into w/ the motor n trans just let me know. Also let me know what u guys did w/ ur drive shafts .. thanks alot
Z28Owner 11-10-2005 07:24 PM
Re: Trans
Your driveshaft should work long as your th350 is a 6 inch tailshaft, you will have to remove the manual crossmember. Which is the hardest part of the whole swap I thought. I took a sawzaw and cut bothside as close to frame as I could. You will ne an auto tranny radiator and steering column unless u use a floor shifter.
cableguy0 11-10-2005 08:05 PM
Re: Trans
the crossmember has to go no way around it. you will need an auto crossmember. a flexplate for an auto trans. also will need a shifter. dont have to swap the radiator. you can just get an external trans cooler which will work better than the radiator anyhow
Tx Firefighter 11-11-2005 05:02 PM
Re: Trans
You'll also need a starter too if your truck still has the original style one on it. The original standard trans trucks used a starter with cast iron nose cone which bolts to the bellhousing with three bolts, rather than to the block like auto trucks and all later model trucks used.
71 gmc sled 11-15-2005 10:29 AM
Re: Trans
thanks alot u guys helped me out alot. I'll have to post more questions!
thanks again
