It's a fact, my engine is cracked
Well it was all good during the summer. But when a cold spell came through in Nov. I got caught slippin. It was below freezing for about a week and I raise my hand as say I did it… “I did not confirm that I had enough antifreeze in the truck”!:o Now the block is cracked !!!! :banghead: Looks like someone took a 10lb slug to it, on both sides just above the oil pan. It’s what I get for working two gigs and not paying close attention to everything.
Well….Game ON!!!! :metal: I need some practical advice and prices of a potential 350 engine I plan to replace my scraped 305. I was going to drop a 327 with Vortec heads and all mods necessary. But I don’t have time for that. I don’t have money for a LT model as well. So I’m going for a Vortec 350 model 90-98; if they exist that late. So please lend me your idea’s on junkyard searches (what to look for/identify) or reasonable priced creates. I’m sticking with the TBI and the 90 models only; unless 2000-02 offer something I can just drop in with minimal changes. I looking to spend in the range of $800 -1000.00 on the long block alone. I hope to get the “Intake and TBI” with it but not get taken for a ride at the junk yard; so I need to now the average price of such a motor. My don’t list: Don’t want a BB. “ “ “ a SB bigger than a 400. “ “ “ another 305 “ “ “ change to Carb “ “ “ change to TPI “ “ “ older model SB “ “ “ nothin but a chevy Why the limitations and being picky, Well….. I’m on a budget, need a quick and easy drop in, want to keep moderate MPG, and I want to upgrade while I have the opportunity. So lets have it!!! Teach me somethin new! What would you do? Thanks in advance. |
Re: It's a fact, my engine is cracked
TBI was 87-95, Vortec was 96-98(99/00 on the SUV's).
Ok.. But could you not use TBI on a Vortec engine or is Vortec strictly TPI?
duh!!! I knew the answer to my own question. Bigarmzz is selling just the part I would need to get away with TBI and Vortec combo. I gotta get more sleep. Thanks Izzy, now I know where to start looking.
yeah, you can run a newer vortec motor in your truck, no problem..
you just need the big ol' $$$ intake that gmpp makes, or you could use a carberated intake and use an adapter (although i really dont recommend that) check out this web site http://thirdgen.org/techbb2/forumdis...?s=&forumid=17 that link should take ya to there "tbi tech board", its for third generation camaro's, but the same concept applys good luck man!:cool: |
I looked into doing the same thing to my 90 Suburban. I found a couple 350 Vortec engines around here for $750. I figured I would have $1100-1200 in it by the time i picked up the intake and built the EGR valve.
You can also pick up a 350 premium long block at Blaines for $640 + core. I put one in my 87 SWB I had a couple of years ago, and it still runs great. They usually try to hose you on the core, but a full core charge is only $400. They come with a 12/12 warranty, too. If you need any help with the swap and whatnot, I am in Arlington. |
Thanks Jonboy, for the info. I'll look into Blaines for the block. I'm not confident in the junkyard engines, unless I going to rebuild it. I have no time for that or traveling to south Texas to mess with Scroggin Dickeys. In my hood, I can't pull/replace an engine without HOA breathing down my neck or I would definitely take you up on a helping hand. I'll just have to pull it to the country in Tyler Texas where I got access to air tools. I got some more upgrades to make like dropping it, installing a 700R4, replacing the suspension and disk break job. I’ll have to wait until spring to jump on it.
Anyone else, who can offer more helpful info, would be greatly appreciated. |
