-   -   Headlight Question (https://67-72chevytrucks.com/vboard/showthread.php?t=188237)
ozzyracing 02-03-2006 10:00 PM
Headlight Question
I have a 65 GMC swb. My problem is if I have my high beams on, all of the lights work (well thats not the problem) but when I hit the dimmer switch only the passenger side light works, any idea what to do?
Woogeroo 02-03-2006 10:13 PM
Re: Headlight Question
The gmc's have dual headlights right? two lamps on each side ? a hi lamp/low lamp on each side ?
reads like yer driver side low beam bulb/lamp is toast...
does the driver side low lamp light at all ?
-W
ozzyracing 02-03-2006 10:52 PM
No, the driver side is not low at all, but if I turn on the high beams, all four headlights light up.
Fred T 02-04-2006 12:00 AM
Did you try a new lamp, or switch the left and right lows around? Also check the connectors in the socket, they can break.
Woogeroo 02-04-2006 06:07 AM
on in this thread on chevytalk, they are discussing headlights and things as well... I thought of your thread here and thought this might be something for you to check.
-W
http://www.chevytalk.org/threads/sho...gonew/1#UNREAD
53chriscraft
See if the rubber plug that is on the radiator support is the culprit. I had only low beams. When I switched to high beams had no lights. Thought it was the dimmer switch, but it turned out to be a somewhat corroded connection inside that rubber conector. Wiggled it and abracadabra.
6066gmcguy 02-04-2006 06:52 AM
First, "CHANGE THE HEADLIGHT!", the low beam CAN burn out and the high beam WILL still work. if that dose not get you light, then you need to go here~~~>HeadLight Trouble Shooting, this is the 6066 GMC Guy site so it will help you out eh.
