-   -   Help!! Difference in 4 speed Bells (https://67-72chevytrucks.com/vboard/showthread.php?t=190892)
harlyworkr 02-27-2006 06:54 PM
Is there a difference in a 292 6cyl 4 speed bell and a 350 V8 4 speed bell for a 2wd truck? I have the flywheel hitting the bell when I converted to a 91 LT1 350 crate motor for my 69 C10. Any help will be appreciated.
JAKES 68GMC 02-27-2006 09:22 PM
Re: Help!! Difference in 4 speed Bells
Doesn't seem like there would be, but I'm no expert on this truck stuff.
NitroMike 02-27-2006 10:26 PM
Not sure. You probably had a 168 tooth flywheel on your 292, but the later set-up used a 153 tooth (smaller diameter) flywheel. Try to use the flywheel that would have come with the later motor and trans.
Tx Firefighter 02-27-2006 11:04 PM
You need to assure that the tooth count of the 292 flywheel was the same as your new 350 flywheel is, either 153 or 168.
Coincidentally, I just swapped this same swap, twice, in the last two weeks in my own truck, 292 to 350, then back to 292. Same bellhousing for all of them.
I then took the 4 speed out and went automatic trans. It was a busy week.
rwgregory 02-28-2006 04:50 AM
Tx Firefighter, just out of curiosity do you use standard nuts and bolts or just
hold everything together with wingnuts seeing as how it only has to hold for a
day or two.....
