-   -   Ign switch (https://67-72chevytrucks.com/vboard/showthread.php?t=1928)
rac72me 04-18-2002 04:39 PM
Ign switch
Is there a chance that with a bad ign. switch, running the truck with it's lights on would kill the battery? (battery not recharging) I have changed the alt. and reg.
bouncytruck 04-18-2002 06:51 PM
I guess it could be. You've got a leak someplace. Lights aren't controlled by the ignition switch though.
'69 K-5 Blazer - 350/TH350, 6" lift, 35" tires
Bothell, WA
Gordo 04-18-2002 07:35 PM
Attach a temperary (or permanent) volt meter to a hot keyed connection at the fuse box and monitor it while your driving. Should read 13.8 to 14.5 with or without the lights on while your running, if not your still having charging problems.
1971 C10 swb stepside 350/700R4/3.73posi
Killingworth, Connecticut
70jimmy4x4 04-18-2002 10:11 PM
Hey Bouncy...
MY lights ARE controlled by the ignition. Actually, mine are controlled by SEVERAL things. Ever turn the light switch knob and have your head and parking lights grow dimmer ???
lol
'70 jimmy 4x4
'98 chevy zr2 (the misses' transpo)
'65 stang
'81 shovelhead
contact me: email--showme219@aol.com
Rod 04-18-2002 10:22 PM
Check the dimmer switch on the floor. Sometimes the plug is poor condition...or the switch is bad. Its a quick easytbing to check,,.. might not be the problem but it eliminates one of the possibilities.
Longhorn Man 04-18-2002 10:34 PM
70jimmy4x4
...you got some electrical issues on that thing. I hope you have a fire ext. in your truck...maybe 2.
Trust me, being in the middle of nowhere on the side of the road with 6 foot flames will put a damper on your day. esp if you are about 1300 miles from home. (don't ask.....very long story)
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
