-   The 1969 - 1972 Blazers and Jimmys Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=36)
-   -   Help troubleshooting.... (https://67-72chevytrucks.com/vboard/showthread.php?t=194120)
red71cheyenne 03-26-2006 07:26 PM
Well, the Blazer runs and I can almost drive it now, just a few things left to fix. How do I troubleshoot the power steering? Deciding whether its the pump or gear that is. Also, how do I adjust the clutch? I have the rod all the way out and can just barely get it in gear. If I adjust it in any, I can't get it in gear. Finally, drum brakes. I bench bled the new master cylinder and then vacuum bled all the lines til I had fluid at all the wheels, but still no brakey? Thanks for the help, and I'll take video next time of the door falling out the back as I drop the clutch!!!! Jeff.
Blazerb61 03-26-2006 08:08 PM
Re: Help troubleshooting....
On the master cylinder did you use the plugs to bench bleed it ? If so redo it with lines into the resivoir always works
hotrodhomi 03-26-2006 09:24 PM
WHen you bleed the brakes make sure you don't run the resivior dry or you will need to start over
red71cheyenne 03-26-2006 10:05 PM
Ya, I bled it with the plugs this time. Do you just use some hose to do it? So that it just dumps back into itself? I'll try that next. Thanks, Jeff.
hotrodhomi 03-26-2006 10:13 PM
I don't... but you can.
red71cheyenne 03-26-2006 10:22 PM
Is there another way that will work better? I tried having the wife pump and hold while I bled, but that didn't work very well either.
ian villeza 03-27-2006 01:00 AM
:bling: The most important part of bleeding brakes is adjusting the brake shoes first.
Make sure you get both shoes seated properly, I tighten then all the way up one at a time till the wheel is totally locked up and then loosen till you get about a turn out of them when you try and spin them. Make sure you adjust each side individually. Makes the whole bleed process a snap and you will have much more solid brakes.:c2:
hotrodhomi 03-27-2006 01:06 AM
I agree^^^ also- sometimes they need to be centered after you replace them. I smack them back and forth with the palm of my hand until they are perfect. Don't hit them with anything hard.
red71cheyenne 03-27-2006 11:11 AM
Thanks guys, I'll try setting the brake shoes first, then bleeding. How do I tell if the rod is adjusted properly on the master cylinder? I didn't change the rod, but the master cylinder is new.
ian villeza 03-27-2006 05:24 PM
When it comes to the rod it's all about free play. The rod should have at least 1/4 inch free play, Meaning that the pedal moves freely before the rod engages the master cylinder. Also I have always been taught and used the theory of bleeding the wheel cylinders farthest away from the master cylinder first. If you have power booster you should be bleeding with engine running for power booster assist.:blah:
71jimmy 03-27-2006 08:57 PM
I agree with you, and in no way am I trying to argue with you, BUT the factory manual says the exact opposite.:crazy: I always thought this was odd, but I never published a factory manual so I went with it. Never did get it to my liking. Now, I'll redo it the way it should have been done in the first place I guess.
red71cheyenne 03-27-2006 09:26 PM
Hmm, well these are just plain old brakes, no power except for my foot! hehe. I adjusted the rod like you were saying, had to move it in about an inch! Seems to be feeling more like there is pedal there. Bled the farthest back one then the other, and the passenger front. Seems to be more pedal now. Can't bleed the driver side front, as the nut is stripped. Guess I'll have to tear the cylinder out of that one and rework the bleeder nut. Thanks for the help guys, Jeff.
hotrodhomi 03-27-2006 10:49 PM
The nut striped on my '81 I had to hammer a smaller wrench on to it to get it loose. It is real soft metal. If you cant bleed all of the brakes then you could still have air. It won't be perfect until you bleed the whole system.
Jason915 03-28-2006 10:07 AM
with your clutch check all of your linkage from the pedal down to the clutch it self you may have worn parts that are not letting you get proper adjustment.
