-   -   alternator/PS brackets-fitment (https://67-72chevytrucks.com/vboard/showthread.php?t=194879)
AspecialZ 04-02-2006 10:39 PM
Well, I have run into another problem and wanted to see if anyone else is in the same boat. I put a sbc 383 in my truck and added an aluminum short water pump, the problem I have is now with the short water pump I dont have a bracket to fit for the alternator. I was told the only way to fix this is a late 60's model corvette bracket. Is this true or can someone shed some light on the subject. Some of you my know about the alignment problem that I was having, turned out a speed shop said that I have to shim the harmonic balancer.:crazy: I thought this part would be easy...herrs some pictures so you can see the heads and bolt holes. thanks all!
corn 04-02-2006 10:52 PM
Re: alternator/PS brackets-fitment
The only thing I can suggest is to get or make a waterpump spacer. Just make the length of it the difference between the two.
http://www.performancepartscanada.co...63510_part.jpg
That or get all different pullies & brackets...
You may also have to make or get a different style powersteering bracket.
Oh wait, you could always get a long pump. DOH
Slonaker 04-04-2006 12:19 PM
You should be able to get an Alaan Grove barcket that will work with it. His brackets are supposed to be very high quality, and are quite reasonably priced. I will probably buy one of his alternator brackets for my '37 eventually.
http://www.alangrovecomponents.com/
Slonaker
bigblock73 04-04-2006 12:44 PM
Alan Grove has GREAT products. I purchased all of my brackets from them and am VERY pleased.
