-   -   how tuff is it to install a tach dash into a non tach truck (https://67-72chevytrucks.com/vboard/showthread.php?t=194887)
tom71 04-02-2006 11:34 PM
my blazer has a full dash and no tach how difficult is it to install? tools need ed ? thanks for the input :metal:
bluec10 04-02-2006 11:59 PM
Re: how tuff is it to install a tach dash into a non tach truck
Sorry, I don't have an answer, but I'd love to hear from one of the members who have done this successfully.
rauto13 04-03-2006 12:19 AM
Are you wanting to use an original tach dash, or add a tach to your existing dash?
I put an Autometer tach in the center hole of my existing non tach dash, had to make a spacer due to the printed circuit board on the back of the dash panel, do some cutting and grinding, wasn't too hard to do.
Ricks1971 04-03-2006 12:24 AM
This guys have a conversion kit for putting a orginal tach in your dash!
http://www.truckandcarshop.com/trucks60_72/t60_032.html
kwmech 04-03-2006 12:45 AM
If going factory style, you need a phillips screwdriver and a 5/16 wrench and the correct harness to hook up to the coil.
72armyswbtruck 04-03-2006 12:51 AM
This is the easiest swap out there going, just unbolt a few screws, unscrew you oil pressure line, and speedo from the back of the speedometer and out comes the console, then just a few screws, to unbolt the bezel and backing plate, switch out backing plates, install the tach, finish with replacing the bolts and there you have it,
that easy
70c10 04-03-2006 07:37 AM
Here is mine with an aftermarket tach and clock. I'm finishing up another one with a Camaro tach and clock soon. Check the FAQ forum for directions that others have posted.
tom71 04-03-2006 03:29 PM
i have a tach dash i just need to know about the wiring is there a harness i need to buy ? im guessing there is , and i did a hei swap will the factory tach work?
byrd 04-03-2006 05:57 PM
Yes the fact tach will work with HEI, and the fact wiring harness will work as well. Just need to cut off the fork lug and replace it with a insulated female spade lug and hook it up to the spot marked tach on the HEI dizzy and your in business. Randy
68speedalert 04-04-2006 01:24 PM
You are correct about the HEI dizzy working, and you and others are correct for the swap if the origional is a full gauge dash. If your origional has just the idiot lights, you need to change the wiring.
GMC Paul's web-site has a tech tip, part-way down the page on how to do it.
http://www.gmcpauls.com/Tech%20Tips1.htm
Numberone son bought a used dash unit that we had to go thru, combining parts/gauges from 3 different dash units to get to it to work. I think someone just plugged the dash to the unchanged wiring....hoping it would work.....and let the 'smoke' out of the gauges.
2bits 05-11-2007 08:47 PM
Jim, those white face gauges look awesome. I usually don't like that because they are usually aftermarket gauges and I like the style of OEM, but that is a clever way to modernize and keep the classic look! I'm gonna think about that when I get to painting my bezel since my interior is black with grey accents. How did you get the gauges mirror imaged like that though? Purchased?
LUV2XCLR8 05-12-2007 04:58 AM
I likey :metal:
