-   -   gear ratio help? (https://67-72chevytrucks.com/vboard/showthread.php?t=195200)
Mcgwirejh 04-05-2006 07:55 PM
gear ratio help?
can anyone tell me what gear ration i have by the number stamped on my ring gear in side the rear end here is the number 1235124 15 41 3 82
68Stepbed 04-05-2006 09:44 PM
Re: gear ratio help?
2.73:1
Mcgwirejh 04-05-2006 10:19 PM
posi or limtied slip
jimfulco 04-06-2006 01:18 AM
The "15 41" is the tooth count of the pinion gear & ring gear, respectively. Divide 41 by 15 & you get 2.73. The "3 82" means it was made in March of 1982.
Look inside the open part of the carrier & see if you see a rod about 5/8" in diameter & 4 intermeshed gears. If that's all you see, it's not posi. If you see 4 or 5 coil springs or an S-shaped flat spring between the two side gears, it's posi. If you see the picture below, it's a Gov-Lock, which is not so good.
http://smg.photobucket.com/albums/v6...h_gov-lock.jpg
