-   -   do these exist? (https://67-72chevytrucks.com/vboard/showthread.php?t=198585)
13lazer 05-07-2006 02:51 PM
do these exist?
has anyone seen an adapter that replaces the glass fuses in the original fuse panel and enables the newer blade fuses to be plugged in ? i guess a small dowell with two flag terminals would do? has anyone seen this?
Longhorn Man 05-07-2006 03:35 PM
Re: do these exist?
nope, and if you could make them, you'd make a bunch. I think I'd buy them personally
Chevrolet4x4s 05-07-2006 05:37 PM
Re: do these exist?
But then you couldn't use a 22 shell for a fuse.......on second thought make a whole bunch
Shane
13lazer 05-07-2006 07:21 PM
Re: do these exist?
mabey i'm on to something, i asked the same question at a napa and they all drew a blank as well. i thought i had seen this somewhere?
dougs69c10 05-07-2006 07:34 PM
Re: do these exist?
painless harness comes with a fuse block that uses blade fuses, im sure you could cut and splice a blade style box into the stock location
