-   The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=38)
-   -   Custom Inner Panels (https://67-72chevytrucks.com/vboard/showthread.php?t=201623)
Frizzle Fry 06-05-2006 03:33 PM
Custom Inner Panels
I moved this from another thread to avoid a hijack situation...
Originally Posted by jmbstudios
What were the steps to make that happen?
1)Bought the wood grain paneling at Home Depot. I think 2 4x8 sheets was all it took at about $10-$15 each. Also bought some foamy insulation tape to go on the top edge of the panels. This gives it a snug fit in the chrome trim.
2) Removed existing ugly-as-sin inner panels.
3) Traced the outline of all panels including all holes onto the new paneling. I made sure all the top edges were cut on one of the horizontal "milled" lines so they all lined up front to back when installed. I also made the left rear panels one-piece instead of split. So pay attention to the gap between those as originally installed if you plan to do the same. Set that gap when tracing the panels.
4) Cut with a fine tooth jig-blade. Put masking tape on the saw shoe to prevent marring the panels.
5) Not shown in my pics, I drilled trough the panels into the doors and tapped w/ 1/4-20 extra holes around the parameter of the panels. So there are 3 screws on the each side and 4 on the bottom. All the same 1/4-20 pan head allen screws.
One thing I might change if I did it again is the rear panels were hard to get all the screws to line up. You might be better off putting them in place and drilling/tapping those screw holes in place.
Also, be sure to use a sealer of some kind on the back of the panels in case they ever get wet back there (and they will even with all new seals/scrapers).
Where did you get the rubbers for the door cranks?
Those are just the standard escutcheons. 7 required for a Suburban. I made the holes in the panels the right size so they clip in. You can get them from any of the vendors. Here's an example ->Link to escutcheons
When can you come do mine???
I have family in Phoenix, but I won’t be coming down there until after the summer months when the sun moves from its current distance of ¼ mile away. :hot:
Frizzle Fry 06-05-2006 03:37 PM
Re: Custom Inner Panels
5 Attachment(s)
Here are the pics:
Frizzle Fry 06-05-2006 03:42 PM
Something I started on and plan to finish at some point:rolleyes: is using parts of 72 deluxe panels over the wood grain. I have all four panels to do it with and I have the matching armrests for the front. Maybe posting this will motivate me to get 'er done... Here's what it will look like:
Long Roof 06-05-2006 04:51 PM
Looks great. Post some pictures of the panels with the 72 sections when you complete them. I have the complete panel set for a 72 also that I might have to modify. Hope you don't mind if I copy your idea.
Aaron
Frizzle Fry 06-05-2006 06:07 PM
Not at all. The nice thing about this is that you get some of the look of the '72 panels without having to change to longer post cranks.
AesC10s 06-05-2006 06:52 PM
damn those doors panels still look great man! i would do that to the 72, but i guess after i get the motor put back together its goin to a new home.....
Aaron
Primered_69 06-05-2006 07:10 PM
I like the way you had the lines in the wood match from front to back
Nightrider 06-08-2006 08:12 AM
Good idea! Looks retro!
cornutz 06-11-2006 12:31 AM
Awesome look... old school for sho!!!
jamis 06-15-2006 01:02 PM
WOW
great job, looks very clean and classic :)
Ron 586 06-17-2006 01:05 PM
Looks good to me. A friend of mine found an old 1952 Ford 4 dr. with a flathead V-8 3 speed with overdrive that had sat for years in a shed. He didn't want to spend a lot of money on it so a set of wal-mart seat covers and panaling for doors, House carpet for floors and headliner. It got a rattle can dark green with white top paint job. He drove it for years proud as he could be. Will died 10 or 12 years ago and I don't know where his pride and joy ended up.
Frizzle Fry 06-18-2006 08:25 PM
Thanks guys. Most people that see it just think it came that way. I'll definately post pics here when I add the 72 panels.
Hart_Rod 07-12-2006 02:39 PM
Any update on the panels?
R
Frizzle Fry 07-12-2006 03:46 PM
No update on anything...:rolleyes: New position, lotza travel, yada, yada...:(
earl87gta 10-12-2006 07:39 PM
Hay Frizzle you did any more work to the pannels yet . Im thinking about doing the same think with Diamond plate aluminum.
NOSguy 10-13-2006 08:58 PM
Would be cool to have the outside of a Suburban "woodgrained" woody style!
Make it look stock as if they offererd that as an option! :)
subtle71 10-13-2006 09:02 PM
That turned out to look quite nice! I like how nice it looks with the green.
ratrod67 10-13-2006 09:08 PM
Very cool!
earl87gta 10-13-2006 09:20 PM
thier is a company that makes a woody kit for the PT cruzer I wounder how much they would charge to do a burb.
Frizzle Fry 10-13-2006 09:39 PM
Thanks guys. No change except that I installed the passenger side arm-rest :lol:
The inner-woody look is what I was going for. Surfburban style. Exterior woody looks pretty cool too. Zumo did one up a while ago. I don't think he'll mind if I re-post it:
67Cowboy 10-28-2006 04:37 PM
Hey Frizzy Fry your Suburban looks nice. I'm building one myself and it has absolutely no interior other than seats and metal door panels. Have you got any photos of what you started with or what you made your patterns with. I have to do headliner and all and need some ideas. By the way I'm just over in Newberg.
Frizzle Fry 11-03-2006 09:09 PM
I started with crapped out vinyl covered origonal panels. Used them as patterns. You should be able to use yours to do the same. If you have no rear panels, come up and we'll pull mine off to make patterns for ya.
Hart_Rod 11-04-2006 10:41 AM
Frizz I don't have any panels to make patterns from, do you have dimensions? Or how much would you charge to make a set like you really have time, LOL. Thanks,
Rob
Frizzle Fry 11-04-2006 12:11 PM
Seems like there may be a common need for these patterns. Should be able to trace them and then get full size copies made at Kinkos. I am moving houses in the next couple weeks (just in the same neighborhood), so I can't do it until then. Ping back in a few if you still need them.
Hart_Rod 11-04-2006 12:54 PM
You da man!
