Needing some crossmember advice
Bought a 67 Step and it is lowered, don't know how far but I am ASSuming around 5-6 in the rear. My question is what does the pinion angle need to be now. Also my stock crossmember has grooved my driveshaft. Do I need to purchase the drop crossmember or change the pinion angle. All opinions are appreciated. Also the headers are the right part # but they are touching the A arm pivot point. Any suggestions? Thanx.
Re: Needing some crossmember advice
So, is this a dumb question or nobody wants to help? New to these trucks and was looking for some guidance.
Here's some info on pinion angles, http://www.2quicknovas.com/happypinions.html
Got any pics??? Would like to see your truck and some of the problem areas.
pinion angle needs to be = to the output shaft of the tranny , but opposite.... Ie -3 and +3
Thanx for the link. This will help out. Iwill post some pics of the driveshaft so maybe you can actually see what I'm talking about.
