WTB A Steel Bed Floor Piece
Looking to by a piece of steel bed floor approximately 12"X12" that is in good condition. I'm sure someone has a piece out there some where.
Thanks, Andrew |
Re: WTB A Steel Bed Floor Piece
I have an old lwb I am cutting up as it is rusted through in several places. Are you needing a square piece or something with a particular section in mind.? I am just south of Wichita so perhaps shipping may not be to rough. Give me an idea what section you need and I can check the bed floor and see if I can help.
Hey Iron horse looking for a piece that is right at the center to the front bed panel, but it reall does not matter as long as it's a good straight no dings piece thanks, I could go buy the patch panel for 24.00 but it's way more than what I need. So I'm just checking to see if one of the board members have a piece just laying around.
Thanks, Andrew |
drew, are you needing the section with the bolt holes for the front panel or just a square 12" x 12" section? Guess I should have asked about that in my first response. Will go look at the bed after I hit submit.
Yes sir you are right on.
Thanks |
Drew67
The bedfloor patch panels ribs don't line up on repos so stay with getting old floor patch panel |
i probably have this. i'll check and get back to you tonight. got to go to work right now.
drew, sorry did not get back to you quicker. After looking at the bed floor I have I don't think I can do you much good. The bed floor is quite rusty and the front panel area is pretty nasty. Lots of pin hole rust and such where the front panel mounts. Sorry for any dashed hopes. Hope roj2323 can come through for you. :(
Thanks anyway Ironhorse it's most appreciated. Anyone else?
ttt
