-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   gearing (https://67-72chevytrucks.com/vboard/showthread.php?t=206738)
62 short step 07-27-2006 05:40 PM
gearing
Took the covers off the diffs today. Found 3.91 in front, 3.07 in back. Not good! The front gears look good, the back looks ok. I like the 3.07's in the back with my 4 speed, it cruises at 50 to 55 mph @ 2000 rpms. What I'm asking is what will the 3.91's do out back? Like I said before the 3.91's are in better shape. I know the obvious would be to put 3.91's out back. What do yall think?
62 short step 07-27-2006 05:45 PM
Re: gearing
By the way the front is D44 5f and rear 12 bolt stock.
b454rat 07-27-2006 07:04 PM
Re: gearing
Well the 3.91 will get you out of the hole faster, and of course turn more rpms driving down the road. You will have more power, pulling hills and such, also good for towing. Im building my burban with 3.08s in it so I can cruise down the road, not screaming rpms either.
62 short step 07-27-2006 08:06 PM
Re: gearing
I called Randys ring & pinion and said could not get 3.91's for the 12 bolt? Didnt think about asking him about 3.07's for front dana 44. For what I use the truck for 3.07's should be fine. Any body got a set?
Americanrider 08-14-2006 12:41 PM
Re: gearing
3.08/3.07's where standard in almost all Blazers, search your local 4x4 clubs B-boards and I'm sure your going to find someone with a axle or 2 for sale. Around here they go pretty cheap on craigslist.
kwmech 08-14-2006 10:31 PM
Re: gearing
My first question would be is what size tire are you running?
There is also 22 percent difference in the ratios
62 short step 08-15-2006 07:07 AM
Re: gearing
I'm running 265/ 75/16 and might go to 305's. Jeremy
62 short step 08-15-2006 07:09 AM
Re: gearing
I've been looking can not find any close to me yet. Salvage yards around here crush things to soon.
b454rat 08-15-2006 07:53 AM
Re: gearing
I will/might be looking for a set of axles with 3.08s, I'll see if I can find a 12b with 3.08s, and pull the gears for yah.
2wdBlazer 08-15-2006 09:43 AM
Re: gearing
If you go to a 305-75-16, that will be a 34 inch tire. Richt now you have a 31.6 inch tire. I would definatly not go with 3.07 and a 34 inch tire. Big mistake. If you keep the same size tires you will be ok.
62 short step 08-15-2006 04:15 PM
Re: gearing
What gears do you think I should use with the 305's? Jeremy
2wdBlazer 08-15-2006 10:09 PM
Re: gearing
3.91 would be fine. That way you only have to mess with the one axle.
How does 2500 rpm sound at 65mph.
http://www.intercotire.com/site63.php
62 short step 08-15-2006 11:05 PM
Re: gearing
Randys ring & pinion said that 3.91s were not available for the 12 bolt rear.
2wdBlazer 08-15-2006 11:52 PM
Re: gearing
Check for a 3.90 ratio. Probably a hard one to get. 4.11 would be ideal for your application anyway.
62 short step 08-16-2006 07:04 AM
Re: gearing
Thanks for the help. I'll let yall know what I come up with. Thanks again, Jeremy
