-   -   Brake lock up problem (https://67-72chevytrucks.com/vboard/showthread.php?t=207205)
KEH 08-01-2006 10:59 AM
My right rear wheel will lock up now and then, usually at low speeds when lightly depressing the brake pedal. Is this a bad wheel cylinder or maybe air in the line? The brakes have been on for several years now. Thanks.
jhow66 08-01-2006 01:10 PM
Re: Brake lock up problem
Bad wheel cylinder or axle grease seal leaking or maybe a brake shoe loose.
Robert1970C20rstbukt 08-01-2006 03:04 PM
Yep, could be the wheel cylinder is rusted and getting stuck. Best thing to do is pull the drum and see what's going on.
hugger69SWBCST 08-05-2006 10:25 PM
Can it be a Master cylinder also? It happen to me an a old 74 and it was that. but again I just only know how to drive only kinda!!
jhow66 08-05-2006 11:56 PM
If it was a master cylinder they would all lock up.
Zeke 08-06-2006 09:32 AM
I had the same problem except it was the left rear, axle seal was leaking. I agree best thing to do is remove the drum and check things out.
LUV2XCLR8 08-06-2006 10:15 AM
Rear brakes can be done with wheel cyl. for under a C-note if you do it
all your self, and if ones bad replace them both, you know Murphy right?
BobbyK 08-06-2006 08:51 PM
Any type of oil or grease on the break shoe will cause it to "Bind" or "Grab" the drum.
Like mentioned..check the outer axle seal and the brake cylinder for leaks.
