-   -   Disc swap...mixmatched parts ? (https://67-72chevytrucks.com/vboard/showthread.php?t=207569)
jasonrmorrow 08-05-2006 02:28 PM
Ok i got all the easy stuff done, spindles/control arms/airbags/discs/ yadda yadda left the part i knew was going to be a ***** until last... go to run my brake lines and nothing seems to work. Heres what i got.
- 72 disc hardlines from a truck dealer
- master and booster from a buddy ( i suspect these to be drum/drum though)
- 82 hoses from the caliper to control arm (front of control arm)
The pieces running across the back of the crossmember are easy...well they are easy to place, not connected yet...
I expect to have to do some fitting to get these lines to fit in my 64...but can you help me identify them...here we go
This is the booster/master...equal resevoir size and a prop valve that looks different than the 71-72 disc prop that i bought used...in the next pic.
http://i3.photobucket.com/albums/y73...astersetup.jpg
http://i3.photobucket.com/albums/y73...rediscprop.jpg
The lines from the proportioning valve should run down and back towards the cab and then to a "t" near the frame rail on the drivers side... these 3 lines make no sense to me, the one short line i think...goes from the front of the drivers side upper control arm under the engine "tower" to the "t".
THe bottom line has a huge 1/2" fitting on the left side of the pic, no idea where that is meant to fit.
http://i3.photobucket.com/albums/y73...sterylines.jpg
And my routing reference...
http://i3.photobucket.com/albums/y73.../discpics2.jpg
