-   -   set screws (https://67-72chevytrucks.com/vboard/showthread.php?t=209426)
76bonanza 08-27-2006 04:18 PM
set screws
I got some new billet window handle look really nice. But is uses set screws and they suck. The litle len wrench things I rounded two of them. Where can you get this things and are the many sizes?
cdowns 08-27-2006 04:30 PM
Re: set screws
what did you round off an allen wrench??? if so just grind it down 3/8 or a 1/4 inch and it will be fresh and ready to go
76bonanza 08-27-2006 04:38 PM
Re: set screws
no the inside of the tiny set screws rounded off.
cdowns 08-27-2006 04:51 PM
Re: set screws
set screws should be available at any locl harware store or auto parts place// i'd try NAPA or CARQUEST first
chevy_fatman 08-27-2006 05:46 PM
Re: set screws
And make sure you get the right size allen wrench, I only rounded off set screws if I don't use the right size wrench.
PanelDeland 08-27-2006 08:40 PM
Re: set screws
He may have set screws that use a flat screwdriver to tighten.If so he needs to make sure he gets new ones in an allen head and the same thread.They will tighten better and stay better,but will also probably be strong enough to break the door handles.
kwmech 08-27-2006 10:26 PM
Re: set screws
When going back together, put a dab of antiseize on them
