-   The 1969 - 1972 Blazers and Jimmys Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=36)
-   -   Blazer Original Jack (https://67-72chevytrucks.com/vboard/showthread.php?t=211499)
Luis_gz06 09-22-2006 10:40 PM
Does anyone with a 69-72 Blazer have their original jack installed. If so, could i see a pic of it of how is it mounted. Also a pic of the original crowbar that was used to turn the jack knob up and down. And was it originally painted with the blazer color or just black. The reason im asking for this, is because i have the jack and all the hardware that holds it, but i don't know how to mount it properly.
Luis.
LUV2XCLR8 09-23-2006 05:37 AM
Re: Blazer Original Jack
IIRC, The jack equipment was all BLACK from the factory. I have the pic of
the jack and tire hoop mounted, but not the tire iron, maybe someone else
will jump in. (btw, this pic is not my own, but it is from a board member) ;)
Huck 09-23-2006 09:30 AM
Believe the jack and the handle extension was the same on the truck and blazer. The handle had a bend in it for the jacking and did not require any tire iron to turn. The kit also included a L shaped lug wrench to loosen the bolts and a small spoon shaped tire iron. If I recall, there was a sticker placed on the back of the drivers side rear wheel tub with jacking and storing instructions. Believe I got a copy of this from "Luv" a while back. Wish I could find an original set of instructions!!!! Huck
LUV2XCLR8 09-23-2006 01:30 PM
I forgot about that :lol:
vtblazer 09-23-2006 03:35 PM
So according to the jack instruction sheet, the one in the pic is not mounted correctly?
LUV2XCLR8 09-23-2006 03:49 PM
Which jack?, read the fine print, one behind drivers bucket is for NO
rear seat option, and one under the hoop is WITH rear seat option ;)
Gary 70 Jimmy 09-23-2006 10:38 PM
Hey that looks like my Jimmy in that picture.
Luis_gz06 09-24-2006 03:54 PM
Thats helpful thanks but, is there anyone that has it behind the drivers seat that could post a actual pic. Thanks.
