alignment troubles
went to have my truck aligned after a complete rebuild, upper and lower control arm shaft kits and ball joints,new drop spindels.but they said they could not get it to what they thought was specs,{their book only went back to 83} not enough bolt for shims to get proper caster and camber on the right side.does anybody have the factory specs for this and toe? if this is true then the right side must have been hit in an accident and tweaked somthing because there is plenty of room left for more shims on the left side,and this would piss me off because i just had the rattleing rebuilt motor out and i could have put another crossmember in at that time.
------------------ project 70 chev swb rebuilt 396bb{402}rebuilt th-400 3.73 limited slip 4/5 drop |
If it's bent...I doubt it's the crossmember.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
it has a new upper control arm on it but reused the lower, thats the only thing i could come up with is the crossmember being tweaked.
I think I would go to another shop and see what they say. Perferably a shop known for doing lowered vehicles.
How did you go about the 4 inch drop in front? ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio [This message has been edited by longhornmail (edited April 23, 2002).] |
about 4, bb on sb springs and 2 1/2 spindels i didn't cut or heat the coils.
