-   The 1969 - 1972 Blazers and Jimmys Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=36)
-   -   Backspacing 20" Wheels (https://67-72chevytrucks.com/vboard/showthread.php?t=219446)
JMac11 12-13-2006 03:35 PM
Found some 20's I can stand. Similar to what Dave johnson has on his Black Jimmy. They come with 5" Back Spacing. Will the extra rim size help the clearance issue? Can get them for a steal, just not close enough to check for fit.
LUV2XCLR8 12-13-2006 06:10 PM
Re: Backspacing 20" Wheels
Depends on the tire size ;)
JMac11 12-13-2006 06:33 PM
They should fit the wheel well. 33x12.50's. I thought there was a steering clearaance issue??
LUV2XCLR8 12-13-2006 06:59 PM
Might be, how much lift do you have again?
JMac11 12-13-2006 09:06 PM
ok.... here goes:
Truck is supposed to have a 4" lift. The distance from the factory bumb stop and the spring retainer on the front axle is > 5".
Existing setup is 285/r70/16 on what appears to be 16"x8" with 4" back spacing
The only thing close to the wheel is the tie rod end and it is CLOSE, but it would be 3 or more inches inside a 20" rim and the distance should remain constant unless catastrophic failure were to occur.
LUV2XCLR8 12-13-2006 10:47 PM
Sounds like it will work, can you test fit them before you buy em?
JMac11 12-14-2006 07:28 AM
nope, great thing about Ebay, ain't it....... Gotta be a riverboat gambler, sometimes.
2wdBlazer 12-14-2006 11:16 AM
I would not even try 5 inches. You couldn't do a u-turn in a mall parking lot.
JMac11 12-14-2006 11:51 AM
?? Lost me there? CLearance or Steering Geometry issue?
2wdBlazer 12-15-2006 12:52 AM
you are putting the tire too close. i was being sarcastic, you may be able to turn but definate rubbage.
70rs/ss 12-15-2006 12:40 PM
The back space issue comes from interferance with the ball joint, but he is talking 20's so it will place the tire/wheel far from the tierod. Most of these trucks like 3.5-4" of backspace, if nothing else steal em on ebay, try em and if they do not fit re-ebay them or just get a 1" spacer to put the wheel at 4" of backspace. Billet spacers are way strong and an inch is not an issue (2" and up I'd be concerned) Good Luck!!
