-   -   Headlight Relay Install (https://67-72chevytrucks.com/vboard/showthread.php?t=220236)
skokie 12-21-2006 03:39 AM
Those of you that did the headlight relay install where did you mount your relays? Post pics if you got em.
nandress 12-21-2006 03:44 AM
Re: Headlight Relay Install
I don't have a picture, and couldn't get one to turn out very well if I tried, but if this explanation doesn't do you, let me know and I will try.
I mounted mine (along with two fan relays) on the back side of the core support on the driver side down by where the inner fender bolts to the core support. It was a tight fit, but it was out of the way. There was a flat spot that fit all four relays nicely.
LockDoc 12-21-2006 11:18 AM
skokie,
Check this thread out:
http://67-72chevytrucks.com/vboard/s...eadlight+relay
LockDoc
John Fabris 12-21-2006 11:52 AM
I too don't have a picture, but I mounted mine on the core support, behind the battery tray, and with the battery in place, you can't see them. I also made a plastic mounting the plate that all of the relays are screwed onto and then used one of the existing bolt holes on the core support to mount it.
skokie 12-21-2006 12:48 PM
John
How did you run your wires on yours?
John Fabris 12-21-2006 02:59 PM
I ran all of the wiring so that it looked like it was stock using the wire gutter along the top of the core support.
I will get some photos tonight when I get home....
skokie 12-21-2006 04:23 PM
Thanks John. I appreciate that.
Brad 12-21-2006 09:31 PM
Here's how I've mounted mine. Looks like a mess that I need to cleanup.
John Fabris 12-22-2006 12:44 AM
Here are the pictures of mine. They are hard to see, but hopefully you get the idea...
http://www.johnnyrods.com/67truck/images/hlrelay1.jpg
http://www.johnnyrods.com/67truck/images/hlrelay2.jpg
http://www.johnnyrods.com/67truck/images/hlrelay3.jpg
http://www.johnnyrods.com/67truck/images/hlrelay4.jpg
http://www.johnnyrods.com/67truck/images/hlrelay5.jpg
http://www.johnnyrods.com/67truck/images/hlrelay6.jpg
http://www.johnnyrods.com/67truck/images/hlrelay7.jpg
skokie 12-22-2006 12:47 AM
John
Yep I see those. Got some more questions for you. Is your wiring new? Also have you noticed if that wiring gets any hotter since you are pushing more through it?
skokie 12-22-2006 01:15 AM
For the heck of it I took my multi meter out and measured the voltage on the driver side headlight while on high beam I got 13 volt reading from it. And 14.10 out of the alternator. Also I did install a new headlight and engine wiring harness about 6 months ago and I noticed when I installed it that the wires seemed to be 1 guage thicker.
krue 12-22-2006 01:24 AM
I used the relay box out of a dodge dynasty and used the installed relays. I mounted it in place of the voltage regulator, it blends in well with the core support and has spots for 9 relays.
nandress 12-22-2006 02:31 AM
Even when you have the relay you will still probably have about the same voltage drop across your high beam light. The biggest difference is that the juice is going directly to your lights and bypassing all that other stuff, which is beneficial when you are doing other stuff (besides measuring voltage drop across your high beam!) Most headlight relays would have 12 guage or bigger going to the power side of the relay because you will likely have a 30 Amp fuse. But it is more efficient, all the same.
John Fabris 12-22-2006 03:16 AM
skokie, I did use a new wiring harness, E-Z Wire, and instead of the wires from the lightswitch/high-lowbeam to the lights, those wires run to the new relays, and then I had to add new wires from the relays back to the lights.
I have not really tested whether they get hot or not... but I am running a bigger gauge wire from relays to the lights..
