-   -   Lights Flicker - upgrade alternator? (https://67-72chevytrucks.com/vboard/showthread.php?t=220351)
53lowdown 12-22-2006 11:13 AM
My headlights flicker when driving and dim when idling, and I was wondering if an upgrade to the alternator is the fix? 69 C10 with what looks like good original wiring. I looked at the thread below about swaping to internal regulated alt, but was wondering if a one-wire alternator would be easier and work as well?
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
shifty 12-22-2006 11:16 AM
Re: Lights Flicker - upgrade alternator?
Before you do anything, I would do the "relay" mod on your headlights if you haven't already. There is a writeup about this in the FAQ section. Headlights will never be dim again, and it might fix your problem.
Otherwise, might wanna test your battery first. Then check your voltage regulator, then have the alternator tested. You can have the alternator and the battery tested free at your local auto parts chain store.
cdowns 12-22-2006 12:08 PM
flickering i'd clean and tighten contacts and most importantly clean and tighten ground wires
jerry moss 12-22-2006 01:26 PM
my daily driver was doing the same thing until i put on a later alternator with a built in regulator. we did it at work one morning when it was slow, only took a few minutes to wire it and i love the difference.
71cheyennezz4 12-22-2006 01:53 PM
mine dont flicker but they god dim at an idle because of my cam
