-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   tcase shifter options? (https://67-72chevytrucks.com/vboard/showthread.php?t=220513)
chosn 1 12-23-2006 11:53 PM
im wondering if anyone has messed around with remotly operating the t'case so that there is no shifter coming thru the floor. for one thing it would make a great anti-theft device espessially if you could lock it in neutral.!!:)
b454rat 12-24-2006 09:08 AM
Re: tcase shifter options?
If you can get the rails to shift smooth and near effortlessly, you could put a cable out of site somewhere, almost under the seat, under the dash, etc.
chosn 1 12-24-2006 11:30 AM
i was thinking o something like a linnear acctuator
jeffspower 12-25-2006 02:34 PM
Is this for your dually project? Since you have an air compressor on board, you could use air cylinders with electric controlled solenoids. One for 2/4wd, another for high/low. It would require reworking the transfer case detents which is no big deal. Plumb the solenoids so when de-energized air is applied to 2wd & high. Then separate rocker switches power them up for 4wd & low separately. It should be a trouble free setup. The main thing to figure out is travel required & the pounds of push/pull it takes for shifting and choosing the right size of cylinders.
jacobs 12-27-2006 09:43 PM
Great idea...just don't accidently shift into 4 wheel drive w/o the hubs engaged while moving. That would be really hard on gears.
